PDA and remote control
I am attempting to use a PDA to remotely control a computer.  However I am getting errors such as "property node 'Property Node': Not supported for current target".
Another error I am running into the the inability to execute subVIs.
Let me know if I should provide additional information.
(5,544 Views)
I tried to intergrate the remote access example into a PDA target which created these errors mentioned above
(5,542 Views)
Hi Thejoeblack,
Thanks for contacting National Instruments.  I've been looking into your question about using a PDA and I have a suggestion for you.  First off, are you just getting started with the PDA? If so, then I would suggest searching in Help>>Find Examples for "PDA."  Here you can find some good examples that I think will help you out.  One in particular is entitled "PDA Tutorial-Pocket PC."  I would suggest looking at this example and the Getting Started Guide located on your computer under Start>>All Programs>>National Instruments>>LabVIEW>>LabVIEW Manuals.  I hope some of this helps and please feel free to reply if you still have some questions.  Thanks!
Regards
Noah R
Applications Engineering
(5,453 Views)
