Boone,
After doing some research and speaking with R&D, I was finally able to figure what the issue is. The LabVIEW PDA module for Palm requires a serial connection to be able to download or debug directly from LabVIEW. The T5 has hardware issues that prevent it from being able to sync over serial so it must use USB, and thus there is no way for LabVIEW to directly download to a T5. Unfortunately, that means your only option is to manually transfer .prc files on the T5. I'm sorry the news isn't more positive, but at least we got things figured out.
Best Wishes,
Message Edited by AESulzer on 05-12-2005 11:22 AM
E. Sulzer
