PDA Emulator
Hello All,
I am developing an application for a PDA. In real life the application uses Buletooth (com8 and com5) to communicate with a instrument. I created a small test VI and run it on the PDA and it worked beautifully.
I wanted to use the emulator to save time but I run into two problems.
1) The PDA Emulator says that no bluetooth device is installed
2) There is a configuration dialog that is used to map the Emulator ports to the computer ports. Say that my computer uses com21 to accept bluetooth transactions. Then I tried to map com1 of Emulator to com21 in computer.  When I did that I get an error "unable to connect to port21".
(3,596 Views)
Here are the dialog of the error i got
thank you for your help in advance
Regards
(3,585 Views)
Hi Zyrmax,
Try to enable Serial with the Pocket PC emulator.
(3,544 Views)
Thanks Smootastic I tired the link and the threads that come with it. I could not solve it yet.
I will keep everyone informed.
take care
(3,443 Views)
