PDA Empty Array Crash Bug
I'm using LV PDA V8.01f1 with PDA fix patch for Windows Devices (the latest).  I build the attached file and download into my Windows Mobile 5.0 device.
The OS crashes at the Array Empty? primitive.
The project is set to Windows Mobile 5.0 with debugging enabled.  After downloading, set breakpoints at both Array Empty? primitives.  It seems the second call to Array Empty? primitive causes a major crash.
Anybody else want to confirm?
BTW, I should be part of the LV PDA Beta program.  I've only signed up hundreds of times within the last year through the ni.com website.Smiley Indifferent  Hope this gets fixed before LV PDA v8.2 release.
Thanks for reading
Robert
(3,155 Views)
Robert,
I tried your code on my PocketPC 2003 emulator and I am seeing the same behavior that you are seeing.  I have filed a corrective action request up to R&D so hopefully they can get this fixed in a future version.  In the meantime as a workaround you could try using an "array size" vi followed by an "=0" vi to accomplish the same thing that the "array empty?" VI did.  Thank you for the feedback.  It is through feedback such as this that we can continue to make LabVIEW even better.
Justin D.
(3,135 Views)
