PCProx By RFIdeas
We are building a piece of Assembly Equipment, totally operated by Labview...our first equipment to ever be built without any PLC's...so far, so good!  We are going to make this one badge accessible (If you are trained to use the equipment, you will swipe your employee badge and you will be able to use it, according to the training you have received).  We are playing with PCProx from RFIdeas...does anyone have any experience using a PCProx on a CRIO with Labview?
(4,207 Views)
From a quick glance at their manuals you will likely want to go with one of the ASCII capable variants of their devices, either the Serial, USB CDC, or PoE variant. From there you will want to refer to this manual (https://www.rfideas.com/files/downloads/manuals/ASCII_Manual.pdf) to communicate with your device either through VISA (serial and USB CDC) or TCP/IP (PoE).
Rolf Kalbermatter  My Blog
(4,112 Views)
That gets me started...Thanks!
(4,071 Views)
