PCIe 6537
I am loking to use PCIe 6537 and I am seeing if anyone has used LabView to interface to it?
Is there any sample code around?
Simon
(3,000 Views)
Hi Simon,
you will find some Examples in the Example Finder. Search for 6537. Attached you'll find the results.
Mike
(2,992 Views)
Hello Simon,
As long as you have NI-DAQmx installed you will have the examples that Mike mentioned in the NI Example Finder.  Also, you can do a NI search for the 653x boards and narrow the search down to see examples that have been created by Applications Engineers here at NI, as well as other users.  This should be a great start, and please let us know if there is an application in particular that you are looking for and cannot find.
(2,966 Views)
If you are new to DAQ programming, check out the following useful tutorial.
Learn 10 Functions in NI-DAQmx and Handle 80 Percent of Your Data Acquisition Applications
http://zone.ni.com/devzone/cda/tut/p/id/2835
Rich Roberts
Senior Marketing Engineer, National Instruments
Connect on LinkedIn: https://www.linkedin.com/in/richard-roberts-4176a27b/
(2,946 Views)
