PCIe 6321 - Error 200077
NE_PKT
Member
Message contains an attachment
At the present state I have tried several examples provided in the forum over the last three days. But I was not able to modify one of them to get it working as desired.
I would like to measure a voltage on (lets say Dev/ai0) while the trigger channel (e.g. Dev/ai1) is above a certain level. Unfortunately the trigger signal is not a digital trigger, so I need to use an analog trigger signal.
Is it possible to use the PCIe 6321 taking one channel as a trigger channel and logging a measured voltage from another channel (Dev/ai1)?
Using the DAQmx functions straight forward causes an 200077 error.
1 REPLY 1
[dennis]
Member
Re: PCIe 6321 - Error 200077
Hi NE_PKT,
as you already see in the Error Message your PCIe-6321 don't support analog triggering.
In my Opinion its no 'easy' way to make this work. You can solve this problem of course programmatically. Read out both channels and make a compare in LabVIEW and just write or save data your interested in.
To find a appropriate Example for your hardware you can select the hardware in the Example Finder to see witch Examples works with your hardware.
Hope I can help
