PCI device Detection
I am working on PXI rack and have an external controller.
All my devices are connected through PCI bus.
The way "Find VISA Resource vi" gves all the PXI devices is there a
similar vi that gives all the CI devices connecte.
Thank you
(3,810 Views)
You can use the DAQmx System property node with the Device Names property selected to retrieve a list of the device names of all of your Devices and Interfaces that show up in MAX.
I hope this helps!
Ed W.
(3,789 Views)
Only if you wait long enough after Windows startup...
I just tried putting my app in the Windows startup folder, and I don't get the proper device list - apparently DAQmx is still busy doing other things.  I had to add a long delay at the beginning of my program to rectify the situation, although I am not comfortable with that non-deterministic approach.  DAQmx badly needs an Initialized, or Ready, property.  Even when not in the startup folder, I have had problems when I manually start a program once I am able to double-click on the icon after Windows startup.
(3,635 Views)
Hello Wired,
This is probably happening because the Measurement and Automation Explorer database hasn't started when your startup application runs.  Rather than just adding a long delay there should be a task you can poll to see if the database is ready using the system task manager.  I will look around and see if I can find the specific task to look for and post back what I find out.
Cheers,
Brooks
(3,605 Views)
Brooks,
No need for that - I already have a workaround suggested by NI apps engineering - I am periodically querying the DeviceNames property of DAQmxSystem until I see it populated.  Although this is OK for my particular app (because I know I must have one DAQmx device in my chassis) it would not work for a more general querying solution.  I think NI should look into making some type of 'Device List Ready' function in a future release.
(3,601 Views)
