PCI-bus extender
I'm looking for a PCI-bus extender that can be used for productiontests.
-32-bits PCI 3V
-Switching the power and bus signals (by software (using LabVIEW))
Can someone give me some advise/info???
Thanks a lot,
Wim Swinkels
Wim Swinkels
Design Engineer
Philips Medical Systems Nederland B.V. Department CIS-HW-ATE
Wim.Swinkels@philips.com
(3,029 Views)
Wim,
I believe that NI's PCI-extender is MXI-3, and it connects to a PXI chassis, which is the PCI bus you want with an addition to the backplane for timing. The cards that would go in such a chassis are the PXI cards. This is a very rugged chassis. If you have a catalog, you can see and read about it there; if not, go to www.ni.com, and search for PXI-1000 or MXI-3 (that's the cable).
Mark
(3,029 Views)
