PCI base address
How do I programmatically determine the PCI base address of a non-NI board?
(4,019 Views)
What platform? If this is Windows you most likely will have to call Windows API functions. And likely some of the group SetupDi... in setupapi.dll. But be warned those APIs are not very LabVIEW friendly. It will be most likely a lot easier to create an intermediate DLL in C/C++ and call that one from LabVIEW using the Call Library Node.
Message Edited by rolfk on 05-30-2010 08:40 PM
Rolf Kalbermatter  My Blog
(3,990 Views)
Thanks for your reply.
It is Windows XP, but will likely become Windows XP embedded.
PC/104+ form factor.
I wonder if anyone has done this (called Windows API functions OR a custom DLL) for LabVIEW already and is willing to post code?
(3,977 Views)
I'm sure it has been done and I'm equally sure nobody will post a complete ready made solution. If you want to do this the right way (TM) you will write a DLL in C/C++ and call that from LabVIEW. The SetupAPI is really not a good candidate to interface to through the Call Library node.
(3,956 Views)
I think you can find it manually on the "driver details" page under windows.  I believe this same information is stored in the drivers *.inf file.  I have done work on PCI register level but i did not use the base address programmatically.  I think i went through a procedure for creating a VISA driver for said device under max, which then enabled you to get a handle directly to the PCI device.  From there you can read the base address and offset into the correct registers.  Here is my original thread which may cover some of those details.
http://forums.ni.com/ni/board/message?board.id=170&message.id=300577#M300577
Craig
LabVIEW 2012
(3,919 Views)
Thanks much for the tip - I will give it a go.
(3,915 Views)
