PCI-8232 Not recognized in Intel Motherboard DH67CL
I am attemoting to set up an ETS on an Intel DH67CL motherboard.  I am using the PCI-8232 Ethernet card that comes with the ETS bundle.  The motherboard has 3 PCI slots and when I place the card in (slot numbering :
Slot 4:  On boot, does not make it through POST and gives the beep codes for not being able to find video.
Slot 3:  Same as Above
Slot 2:  Gets through boot, starts the LV USB Utility.  When I run "7. Evaluate System".  I get a error:
"No supported network device found. A network adaptor with a supported ethernet chipset is required."
Because of the form factor of the computer, I will need to get the PCI-8232 working in Slot 4.
I have upgraded the BIOS to the latest available from Intel.
Bad card?  Incompatible BIOS?
Message 1 of 15
(4,410 Views)
Still can not get passed this. Can't boot into safe mode or format because USB boot can not find the network card.
With the card in slot 2 I can see a 32 bit card 33Mhz is present. Inside the BIOS diagnostics. Other slots, I don't even get past POST so it is impossible to tell.
Message 2 of 15
(4,400 Views)
Hi, I found these KBs related to your hardware. Try to follow these steps to enumerate your device on your PC.
Link1: http://digital.ni.com/public.nsf/allkb/7AEC81D93341F70686256AD800726906?OpenDocument
Link2: http://digital.ni.com/public.nsf/allkb/5827EA5251039A0A86257513007A9B22?OpenDocument
Message 3 of 15
(4,395 Views)
Mike,
I am not sure I follow. These look to be for installing the PCI-8232 in a desktop computer with Windows installed. I am installing the card in a desktop with no OS and setting it up as ETS.
Message 4 of 15
(4,392 Views)
I'm not familiar with ETS, it is like a real time os or a bootloader?
Best Regards,
Miguel Fonseca
Message 5 of 15
(4,382 Views)
It is the real-time stand-alone.  I am essentially installing per:
http://www.ni.com/pdf/manuals/371857f.pdf
I am configuring using a USB and then formating and installing the RTOS.
Message 6 of 15
(4,376 Views)
First I'd like to ask you, which processor you are working with?
Then, I found this information related with your board and the ETS compatibility:
Mother Board: http://www.intel.com/content/www/us/en/motherboards/desktop-motherboards/desktop-board-dh67cl.html
Requirements to run ETS: http://digital.ni.com/public.nsf/allkb/D83956770EF7D69B86257405005D2675?OpenDocument
Does your board completes these requirements?
Best Regards,
Miguel Fonseca
Message 7 of 15
(4,346 Views)
I am guessing you meant to link to:
http://zone.ni.com/devzone/cda/tut/p/id/8239
The processor is one of those listed, an intel i-3 sandybridge (i3-2100). I am using LV2011. So it should be compatible.
Message 9 of 15
(4,339 Views)
Hi bradth,
Thank you for the details of your system. To begin, first let's run a compatibility test on your system by using the utility found in this KB Article (http://digital.ni.com/public.nsf/allkb/9209361E17708D548625744A007FF353). Please post a screenshot of the results so we can take a look at the full configuration of your sytem. Let me know if you have any questions. Thanks!
Aldo A
Message 10 of 15
(4,319 Views)
