05-22-2007 04:41 AM
05-23-2007
02:09 AM
- last edited on
06-30-2025
02:10 PM
by
Content Cleaner
Hi Mosgaard,
Can you provide an error code for me? Is your PCI-6534 Onboard memory Looping enabled?
You might also consider the PXI Express versions: PCIe-6536/37 boards have a better performance than PCI-6534 and they are built for the PCI Express bus, which has the ability to transfer large amounts of data at high rates without any glitches. This removes the need for expensive onboard memory, lowering the cost of the digital device. In the case of the PCIe-6536/37, the pattern is stored in PC RAM and is continuously streamed to the board.
Please let me know if you need more infomations on this issue.
Best Regards!
05-23-2007 06:10 AM
05-23-2007
06:54 AM
- last edited on
06-30-2025
02:10 PM
by
Content Cleaner
Message Edited by Morini on 05-23-2007 02:21 PM
05-23-2007 06:59 AM
It is the same VI without the DAQmx property node.
I get the following error message: Error -200279 occured at DAQmx Read (Raw 1D U8).vi:1.
05-23-2007 07:52 AM
05-23-2007 09:49 AM
I just triede the example - and it works ![]()
Thanks for all the help.
