PCI 6503 limitations
What is the fastes I can switch in and output signals from a PCI 6503? I'm running LV 8.0 from a computer using linux (fedora).
Thanks!
(2,649 Views)
Since the 6503 has static DIO you'll have to control the transition in software.  Typically, the determinism of software is limited to around 1kHz, but this is a function of your actual system.  I'd recommend you investigate our M-series line of Multifunction DAQ cards which all have at least one port of hardware timed DIO.
Low cost solutions that you might consider include the PCI-6221 or perhaps the USB-6251.
Let me know if you have any more questions!
Message Edited by Elijah K on 04-02-2007 12:24 AM
Elijah Kerry
NI Director, Software Community
(2,632 Views)
