07-09-2007 04:48 PM
07-09-2007 04:50 PM
07-16-2007 10:02 AM
The while loop should only be around the read function. With the create channel and timing vi's u configure the channel and the buffer (in the memory of t he pc) where the board will insert the data. Then the only thing u have to do continously is to read from that buffer to avoid overflow.
See attached image as example.
(if u still have problems make a reset device of your board from max).
