PC Data Acquisition & Sensors
I need a PC based Data Acquisition system with competible sensors for a 10 mili-second test.
Need to collect data under 10 miliseconds and I need pressure sensors, flowmeters and at least one load cell.
8 inputs (/outputs) should be enough but as tests develop we may need more like 25 inputs
Please let me know what kind of system I need.
osman akad
cell in Turkey (533) 686-5958
(2,525 Views)
Hi Osman Akad-
If you will be using bridge-based pressure and load cell transducers you should probably consider an SCXI-based system.  This would require you to select a multifunction DAQ card (perhaps M Series), an SCXI chassis (SCXI-1000 or SCXI-1001) and some modules with which to excite your transducers and acquire their responses.  For load cells and pressure transducers, the SCXI-1520 would be an excellent choice.  Assuming your flowmeter will output a voltage proportional to flow rate, you should probably select an isolation amplifier SCXI module that would be well suited for general voltage input.  The SCXI-1125 would be a good choice for these input channels.
Of course you would also need cabling and breakout accessories for each of these modules.  I would encourage you to contact your local NI sales office so that you can discuss your application in more detail.
Hopefully this helps-
Tom W
(2,502 Views)
