/PAE does not help
Hi group,
today I got 4GB DDR2 RAM for my desktop and tryed the /PAE switch with Windows XP.
I found no difference with Labview 8.5. My programm crys out of memory at the same data set sizes which I expect to use < 1,5 GBytes RAM.
Have somebody noticed improvements in labview usuable memory with the /PAE switch?
(3,035 Views)
How did you calculate how much RAM you application will use? What size is your largest array?
Remember that arrays need to be contiguous memory, so the problem could be caused by memory fragmentation. See e.g. the following post:
Is this discussion related to your previous thread? In this case it would help to keep it all in one place instead of starting a new thread to avoid fragmentation of the discussion. 😉
(3,026 Views)
I calculate it up from profiling it with smaller data set sizes which cause no errors.
Largest array would be 2*4*16.000.000=~128MB, last working size is ~96MB.
H'm isn't memory fragmentation not an issue with intel processors >=i386 because of the virtual addressing of the memory through tables pointing to peaces of 4096 bytes which can be randomly scattered in physical ram but are logical contiguous.
Is but is a different problem and can be handled on it's own.
The other problem was how to minimize memory usage, this is maximize usuable memory
Off course both can solve my base problem.
Message Edited by IngoWolf on 02-29-2008 10:25 PM
(3,008 Views)
Howdy IngoWolf,
You may want to explore the /3GB switch, see Extending Virtual Memory Usage for 32-bit Windows.  This takes virtual address space away from the kernel and allocates it to user mode applications.
Note that fragmentation of virtual memory is still an issue on x86.  If you have a buffer that is 128MB, the memory manager has to find a contiguous 128MB hole in the virtual address (VA) space.  The memory manager is more likely to succeed if you try to allocate 2x 64MB buffers because it only has to find 2 64MB contiguous holes in the VA.  It is easier to simulate this problem if we talk about buffers of say 1 GB.  By default, Windows allocates 2GB of virtual address space for applications.  However, Microsoft system files reserve 0x70000000-7FFFFFFF (256MB) and MS recommends that 3rd party DLLs reside at virtual address 0x60000000-6FFFFFFF.  So, you're left with around 1.5GB of contiguous virtual space for your application (code) and buffers.  Any code or data that loads into the middle of this address space would reduce the maximum buffer size that you could allocate.  If a tiny DLL loads into the middle of VA, you still have roughly 1.5GB available, but the largest allocation chunk would be about 750 MB, due to the fragmentation.
For example:
Virtual Address Space
0                                    1.5      1.75    2.0 GB
  App                              DLLs  System
          { ~1.5 GB Avail }
Traditional NI-DAQ loads around address 0x21400000 for "legacy" reasons, lets take a look at what happens:
0                                    1.5      1.75    2.0 GB
  App       TDAQ             DLLs   System
         { A }        { ~1.0 A}
So, if someone wanted to use large buffers (>1GB) with Traditional NI-DAQ, they would have a challenge.  Generally they would move it somewhere else in the virtual address space (hand defragmentation) using the palbase utility.
The 3GB switch makes this:
0                                    1.5      1.75    2                     3GB
  App                              DLLs  System
          { ~1.5 GB Avail }                          {~1GB Avail }
So, with 3GB, you could not allocate a large 2 GB buffer, but you could allocate 2.5 GB of buffers.
I hope that helps.
Jeremiah
NI
(2,906 Views)
