Overlaying an IMAQ Image with Waveform Chart
Hi everyone,
I am trying to overlay the values of some sensors over an IMAQ Image stream, similar to having a waveform chart. The vision application is going to be run on a real-time CVS, so I cannot use invoke nodes for a waveform indicator to export the image. I know a (tedious) solution would be overlaying the IMAQ image with simple entities that creat such a chart, like lines, points and texts, but I was wondering if someone can think of a simpler solution.
Soheyl
Message 1 of 10
(4,653 Views)
I really get a bit confused .do you want to overlay a waveform on image ?
Message 2 of 10
(4,628 Views)
Yes Hatef, that's exactly what the OP said.
I can't think of any way other than building up the chart yourself using overlays.
Maybe, you can try saving the IMAQ image and doing the opposite?  You can set background images for charts/graphs.  Save the image.  Then, use a property node to set the background image using your IMAQ image?
Message 3 of 10
(4,623 Views)
this is two way to do some thing like this
Message 4 of 10
(4,617 Views)
I don't know -- I just hooked my camera up to an IMAQ Image Indicator and put it in a loop to show me a video.  That worked (of course).  I then put into the same While Loop a Get Date/Time function, wired it to a Time Stamp indicator, and put that indicator right on top of the Image Indicator.  When I ran the VI, my video had the current Date and Time showing on top of the video.  No special "magic" or code ...
Message 5 of 10
(4,612 Views)
I also vaguely remember (from several years ago, before NI changed to the "2" versions of some of their Vision functions (LabVIEW 2010?), but they might be present in Version 2, as well) that it was possible to put a formatted Text string at (I think it was) the top of an Image.  I don't recall whether it overlaid the Image (as my example does) or just appeared "on the border" ...
Message 6 of 10
(4,607 Views)
That "solution" works for something like a timestamp.  But, you'll notice the timestamp completely covers the image.
How would that be plausible if you're using an entire graph over the image?  You won't see the image.  You may as well eliminate the image at that point.  There's a great deal of "magic" required to get what you're doing to work for what the OP asked.  ((This is entirely ignoring that it's a bad idea to stack objects on top of each other for performance reasons))
Message 7 of 10
(4,593 Views)
Thanks Hatef.
Yes, I know I can break down the chart to many entities and plot them myself, as you have suggested. The problem is it is a lot of work to do that for several waveform charts. It is also a bit more complicated than your suggetion, cause like a waveform chart, I want the value to scroll in time, during the recording, so I will need to keep a history of previous points, and overlay all of them. And all the axes, ticks, text, etc. I was wondering if it is a simpler way, like overlaying the image with a bitmap of a waveform chart.
Message 8 of 10
(4,582 Views)
natasftw and Bob,
One thing that I forgot to mention is that I want the video of the image plus the waveform overlay be saved on the CVS. I don't have a PC runnig all the time (and connected to the CVS), so I cannot use the waveform chart image.
Bob,
Yes, I can use the overlay functions, as I mentioned in my original post, but it is not just a simple text. It is going to be several arrays of numbers, scrolling in time, plus the axes, titles, legends, ticks, etc. I will do it if I cannot find a simpler solution though.
Message 9 of 10
(4,580 Views)
Have you tried updating the background of a waveform chart yet?
http://digital.ni.com/public.nsf/allkb/FF55BDA8C9F0C0ED862573450053A425
This shouldn't matter if you're on the CVS or a PC.  It'll make the chart as you want.  You update the background image.  After that, you can use the get image method:  http://digital.ni.com/public.nsf/allkb/5AE4ADCBB65A6D8F86256FBF007A1AC1
Message 10 of 10
(4,577 Views)
