OverflowError DAQCard 6036E
I'm trying to install NI material on a new computer (DAQ card 6036E). I installed LabVIEW 8.2 with the different drivers.
When I try to test the material, an error message is appearing (error message n°-10845 : OverflowError)
I had a look into the help and the detailed message is the following one: "Because of system and/or bus-bandwidth limitations, the driver could not read data from the device fast enough to keep up with the device throughput; the onboard device memory reported an overflow error."
What can I do to solve this problem ?
Thanks for your help
(2,489 Views)
