Outputting a voltage for a required time
I have a labview circuit integrated to a myDAQ. In the labveiw circuit I wish to output a voltage for ONLY a required period of time (eg 10 seconds) then switch off again, before running the circuit again. I understand how to loop the circuit, but not how to only apply the voltage for a certain length of time.
Thanks for your help.
(2,885 Views)
for an elapsed time after the Vi has started...use the "elapsed time.vi" in the timing pallete and if it is for a specific time in the future? use the get time vi functions....
do a generic forum search on "time," your question has already been answered there.....Smiley Wink
(2,875 Views)
Thanks for your help but I'm not sure you understood what I was asking. I understand the elapsed time, but isn't that just waiting before it runs? To go into a little more detail ...
I need an ouput voltage for 10 seconds only. I then need the voltage to return to 0V, then start the circuit again.
(2,857 Views)
Write your output, wait the designated amount of time, write a 0 to the output.  Put everything into a loop.  Sounds like you have all of the peices.  Where are you stuck putting them together?
(2,853 Views)
sounds like you need a simple state machine...tells us how you want the user to interact with the program, step by step and case statement transitions. better yet....post your code
(2,830 Views)
