Outputting Analog Current
I would like to be able to control a device with a 4-20 mA signal in the most economical way.  We are already using aPXI chassis but we do not have a way of creating analog output.  Right now I am seeing the USB 6008 as the best option because we do not need that fast of a sample rate.  Are there any other options that I am not seeing?
(2,911 Views)
You will also need 249 ohm precision resistors as the DAQ has voltage inputs/outputs, which will have to be "converted" to current values.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,910 Views)
The positioner on the valve assembly has an equivalent impedance of 550 ohms already and the USB 6008 only outputs a 0-5 V signal though
(2,897 Views)
If you are trying to actually control a positioner then you will probably need more than just a DAQ card. 4-20 mA is usually a communications "protocol", rather than an actual "driver".
Putnam
LabVIEW Champion
(2,882 Views)
There are off-the-shelf converters for 0-5V in to 4-20mA out, they are typically bandwitdth limited to 100's or 1000's of Hz.
Dataforth makes a wide variety of conditioners and isolators, there are a lot of other companies too.
-AK2DM
(2,879 Views)
