Output without using NI-DAQmx
How can I give output signals using LabVIEW directly from the CPU without using the NI-DAQmx box?
I wish to output signals to an ICE engine by taking output from the CPU. How may I do this?
Thanks 🙂
Dheeraj Bharadwaj
IIT-Madras
(2,659 Views)
Hi Dheeraj,
What do you mean by ICE engine? The activeX functions might be of use to you, the following help explains its uses.
https://www.ni.com/en/shop/labview/activex-and-labview.html
Hope that helps
Joel G
National Instruments UK & Ireland
(2,643 Views)
