Output Arbitrary Signal in Labview, Generated in MATLAB
Hi
I'm trying to generate a signal from LabVIEW that has been created in MATLAB.
I've tried using the 'Simulate Arbitrary Signal Express' block in LabVIEW, however it only allows me to load .lvm files
Is there any way I can load from a .txt file? Or any way to generate an .lvm file from MATLAB?
Thanks!
(3,228 Views)
Hi ghp,
use "ReadDelimitedSpreadsheet" ("Read from Spreadsheet File" in older LV versions) to read txt/csv files…
(3,222 Views)
Hi
In doing so I was able to import correctly a .txt file containing the signal from MATLAB, and can view it as an array in LabVIEW.
However, I am unable to successfully export it as a .lvm file
The initial .txt file contains two columns with numbers, which is loaded correctly into LabVIEW, however when attempting to export it as .lvm using 'write to measurement file', it does not export correctly
Any advice?
See the attached screenshots for the code I am using
(3,200 Views)
Hi ghp,
using this sample code I create a LVM file with two data columns:
In which way it is "not correctly"?
Please attach your code and your test data (txt file and your LVM file)…
(3,196 Views)
