Oscilloscope + Labview oscilloscope driver + Labview = Bode Plot
Hello.
Maybe someone knows how to create a Bode diagram in Labview with an oscilloscope signal? I downloaded the driver for my oscilloscope to work with Labview. If you know how to do that, please take a photo with instructions.
https://www.youtube.com/watch?v=IVFFyj-U7Jo&feature=youtu.be&t=37 Oscilloscope data sheet https://mediacdn.eu/mage/media/downloads/SDS1000X-E_datasheet.pdf Labview driver for the oscilloscope https://www.siglent.eu/Downloads In Tektronix oscilloscopes, Bode Plot can be executed via Signal Express. Unfortunately, I do not have a Tektronix oscilloscope.
Message 1 of 8
(5,389 Views)
A Bode Plot is just a frequency response curve, right?
As you sweep through the frequency range take measurements with the scope at regular intervals and plot those measurements on an X-Y graph with frequency in the X- Axis and amplitude in the Y-Axis
=== Engineer Ambiguously ===
Message 2 of 8
(5,329 Views)
You can't create a Bode plot with just an oscilloscope.  You also need a cyclical signal of some kind (usually a sine wave) and a way to sweep it through a frequency range.
You can use LabVIEW to simulate the whole process though.  Here's an example of sweeping a sine wave to measure a filter response and viewing the results as a bode plot:
https://forums.ni.com/t5/Example-Programs/Bode-Diagram-Plot-Using-LabVIEW/ta-p/3504314
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 3 of 8
(5,310 Views)
 RTSLVU, this method will not give an exact result. Bode Plot(Frequency response) is better.
NIquist; Yes, I need something like that.
To generate a sweep signal, I use a signal generator. https://mediacdn.eu/mage/media/wysiwyg/siglent/Downloads/DataSheet/SDG1000X%20Datasheet-en.pdf
The oscilloscope is connected to a computer. On the computer, LabView with a driver for my oscilloscope. How to embed Bode Plot in my LabView driver so Labview uses signals from my oscilloscope and creates a Bode Plot?
https://www.youtube.com/watch?v=UmTAhIrVids On the video in the oscilloscope there is the Bode Plot function, I do not have such a function in the oscilloscope. Therefore, I need a computer and LabView for this.
Message 4 of 8
(5,248 Views)
For a transfer function you should know the exitation or measure it 😉  (and the response ...),
if you have simultaniously captured both signals (your scope has at least two channels :D) , you can use the math or signal processing vis to calculate the transfer function (usually you have to decide wether you do it mainly in time or frequency domain ... )
Wether you use a stepped sine, multi sine, noise, chirp ....  is up to your needs and programming skills.
To analyse potential differences between the two channels, just swap them 😉  (and use both data and the geometric! mean)
Greetings from Germany
Henrik
LV since v3.1
Message 5 of 8
(5,188 Views)
Sure, you will need to do some processing but the method of measuring the output with the oscilloscope, processing and plotting it in an X/Y chart is exactly what everyone else is telling you to do.
Message 6 of 8
(5,165 Views)
Electronics is my hobby. A thousand apologies, I did not understand something about how to make X / Y Bode Plot.
I made a Bode Plot (not an X / Y Bode Plot) using a signal generator and an oscilloscope (image 1).
RTSLVU, How to take measurements with an oscilloscope at regular intervals on this Bode plot (image 1)? Maybe this is done using programs such as Matlab, and the analysis should be done on a computer? On my oscilloscope I did not see such a function that it was possible to take measurements at regular intervals.
On my oscilloscope, measurements can be taken at regular intervals only using cursors (image 2).
What result should I get I understand:  frequency in the X- Axis and amplitude in the Y-Axis. I do not know how to do this.
Message 7 of 8
(5,123 Views)
I don't know what oscilloscope you are using but every scope I have used with LabVIEW that could do on screen measurements cold also do the same measurements remotely using LabVIEW.
Message 8 of 8
(5,111 Views)
