Original Image does not display
Hi guys, I am wondering why the original image does not display on the front panel view. Can you please help me to identify the problem? Attached here are the snipped images of my code. Thank you.
(3,169 Views)
If you want to preserve the original image without getting changed/modifed/overwritten you should create extra IMAQ Create(User buffer).
-Original image is the reference for the image which you created and if you don't connect Img Dst for some operations the Img Dst Out overwrites the source image.
-And check the display palette for image indicator based on the image type.
uday
(3,163 Views)
Share the Actual vi/Snippet instead of Image.
(3,144 Views)
