Options for PT100 RTD temp sensor into Labviw - USB8451 possible?
What are my options for obtaining PT100 RTD temperature sensor into Labview?
Is it possible with a NI USB-8451, or what about reading into an ardiuno then into labview? I cant seem to find any accurate information on any of these two options.
Is there a cheap alternative?
(4,400 Views)
Hi Natejk,
the USB 8451 is a serial communication module, it cannot handle pt100 sensors directly.
An Arduino would be a cheap solution: use a voltage divider to convert the resistance change of the pt100 into a voltage change you can measure with the Arduino...
(4,344 Views)
Duplicate thread: https://forums.ni.com/t5/Multifunction-DAQ/Temperature-Sensor-PT100-RTD-and-NI-USB-8451/m-p/3671330
(4,334 Views)
