Optimizing an objective function (Holt's exponential smoothing)
Hi there,
I should create a programm carrying out Holt's exponential smoothing for a raw data (https://en.wikipedia.org/wiki/Exponential_smoothing#Optimization). I've managed to create a block diagram for the case when parameters alpha 1 and 2 is entered by a user, yet the next step is to make up a program calculating alphas itself by optimizing an objective function (SSE, the sum of (y-y')^2, y - raw data, y' - data by smoothing).
I tried to use Optimization VIs, but there's no result, since in all cases there must be the model described, and I haven't a clue how to make a description.
There is a snippet attached, but it's a little cluttered, sorry for it.
(2,907 Views)
The top loop can be optimized/removed be replacing it with Array subset and a Subtract, no loop needed. For the bottom loop i have no suggestions right now. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,799 Views)
- Do you need to calc 1-alpha several times?
- Move constant operations outside the loop!
- I prefer shift registers for clarity of the code.
(2,797 Views)
