Optimize increment or decrement operator for FPGA
Hi all, i'm wondering if there is a solution to optimize the increment +1 or decrement -1 operators for execution speed having as target increasing the SCTL clock speed.
I mean substitute those operators in the same fashion as the equal to zero is optimized converting a number to a boolean array and after that checking bit to bit and putting an AND or OR operator (attached pic)
(2,748 Views)
Are you running into issues becaue the integer data type you are using is much larger that what is required? If you use compact fixed-point types instead of integers you will most likely not be able to implement anything faster than what the compiler generates for those operators. For instance, if you only need a 4-bit values, use a fixed-point type configured to that and then use the standard primitives. No bit-twiddling required, the compiler will do it for you.
(2,726 Views)
