Optimising code using multicore
Morning all,
I have a piece of labview code that I want to run 10,000 times, varying my input parameters to see the effect on the output (Monte Carlo simulations). The output of 1 run does not affect the input to the next, so I can define an array of starting parameters. Will my code run more efficiently on a multicore processor if I have 4 For loops, each of 2,500 runs as 1 For loop of 10,000 runs? Is there anyway to optimise this process?
Paul
"When I read about the horrors of drinking, I gave up reading"
(4,098 Views)
Accepted by topic author MancPablo
Please refer following links: https://www.ni.com/docs/en-US/bundle/labview/page/configuring-parallel-for-loop-iterations-to-tweak-...
and this : http://www.ni.com/white-paper/6423/en/
uday
(4,091 Views)
For those who are too lazy to hit the links:
The solution is to use a Paralllel FOR Loop.  You can configure the FOR loop to run several iterations in parallel.
(4,062 Views)
