Opening subvi frontpanel as the foremost window
I am using an external software to run a subvi. I want this subvi to appear ahead of all other windows when called. I am using the vi property node FP.IsFrontmost and I have the vi properties set up in a custom modal configuration. However, when the vi is called it appears in front of all other labview vis but does not appear in front of any non-labview windows. Is there any way to extend the reach of FP.IsFrontmost outside of just labview software? I am using labview 2010 but I can use 2022 Q3 alternatively if there is no solution for 2010.
(221 Views)
Are you on Windows?
Then maybe use Call Library Node with user32.dll.
Function FindWindowA wired into Function SetForegroundWindow.
(187 Views)
(149 Views)
