Opening dialog box through subpanel
Thanks a lot, this works perfectly!
One more thing though: if I run the Main.Vi, use it, stop it and then run it again. The manual/automatic.vi's obviously keep running and the Main.vi gives me Error 1198. The only way I got around this problem, is by just aborting everything in the end (which is not a very smart idea), wiring a stop button from the Main.vi to the stop-case in the manual/automatic.vi's (by using them as subVI's) does not seem to work.
I feel like I misunderstand some very fundamental LV concepts here, I tried a lot of other sources and examples before starting a new topic for this basic stuff but I can't get it to work.
Message 11 of 17
(421 Views)
Hi Phlop,
I would reorganize the whole project!
  • Why do you even need two different VIs for "automatic" and "manual"? There should be only one VI to show the UI and update all indicators…
  • In "manual" mode the use is allowed to change the control values (aka valves, …).
  • In "automatic" mode the controls are disabled and will be controlled by your "automatic logic". No need to duplicate all those frontpanel items…
  • You also should think about separating the UI from the internal program logic (in the long run). This would help to implement your "automatic logic" as it will not depend on UI elements…
  • If you insist on using separate VIs for both modes: implement them as QMH and have them communicate with your main VI. Now it is VERY easy to send a "QUIT" command to your message handler(s)…
Message 12 of 17
(417 Views)
Hi, I wanted to use two VI's because the "manual mode" is going to be password protected. A lot of students will be using the station, not everybody should be able to open valves at will and accidenticaly destroy multiple thousand € of equipment. That's why the manual is full of controls and the automatic full of indicators.
That's probably a good idea, I wanted to use subVI's for the automatic processes (e.g. press "dock new shuttle" and have the valves toggle depending on pressures and some user inputs).
Okay, can't say anything to that as I don't know what QMH is. Will have to take a crack at it!
Thanks for the tips!
Message 13 of 17
(413 Views)
Hi Phlop,
QMH = Queued Message Handler
LabVIEW comes with an example…
So you should start in "automatic" mode and enable the "manual" mode only after password check.
Still only one VI…
Message 14 of 17
(410 Views)
Did you see my note in the "Panel Close?" case?
Message 15 of 17
(400 Views)
Yes I did. That's exactly the problem. A "clean" way to shutdown to me, is to let the programm finish executing (stop the subVI's while-loop in my case). But as I said, it didn't work the way I tried.
Message 16 of 17
(396 Views)
Then I'll have to find a way to lock all the valve-controls in "automatic" mode. I still need to see the valve-state (open/close, green/red) on the FP. I've seen a lot of "locked and greyed out" in connection with controls in other VI's. Maybe that's a more elegant solution in combination with the "Multi-Segment Pipe"-control from Paul.
Message 17 of 17
(391 Views)
