Thank you for contacting National Instruments. I am not sure if I fully understand what you would like to happen. In Measurement & Automation Explorer (MAX) if you associate a channel with NTSC, RS170, or one of the other standards, then those channels will retain that setting. You should not have to reassociate a given channel with NTSC every time.
You will have to click to expand those few folders in order to get to the channel every time MAX opens, but that should only take a matter of seconds and nothing else should be needed. Also, generally I continually have MAX open, even if I am running program in LabVIEW or any other API, that way I do not have to continually reopen MAX.
If this does not answer what you were asking, then please let us
know and we will see what else we can do for you.
Michael
