Opening Excel from LabView
    Hey all,
I am trying to figure out how to open an Excel document from within a running LabView .vi.  I have been looking around here but I can't seem to find exactly what I am looking for.  What I have is a GUI running to operate some test equipment.  The user needs to be able to create and load a configuration file that is created with Excel.  I have added options to my Run Time Menu to make this easy for the user, but I can't figure out how to actually execute it in the code.
I plan on having the template they will use at a location like this:
C:\Program Files\Naitonal Instruments\LabView 8.2\Templates\Interrogation Setup.xls
So I am trying to figure out the best way to execute this.  I was going to use the System Exec.vi but, being a DOS prompt, it can't handle the spaces in the directory.  Is there a better way for me to do this?
Really appreciate it.
(3,642 Views)
Hi twayne,
you can use the "Open URL in Default Browser.vi". Connect your path to it.
Mike
Message Edited by MikeS81 on 07-09-2008 03:36 PM
(3,640 Views)
You can interface excel via ActiveX in LabView. Have a search through the forum with these keywords. There is also a thread containing links to excel related threads, but I've no bookmark at hand.
Felix
(3,637 Views)
Hi twayne,
if you want to read/write from/to the excel file, then see this link http://forums.ni.com/ni/board/message?board.id=BreakPoint&message.id=2391#M2391
Hope it helps.
Mike
(3,634 Views)
Aha!  Mike your answer was perfect.  Thanks!
I haven't gotten into usnig the ActiveX funtions yet, so the simpler the solution the better.  Smiley Very Happy
(3,631 Views)
