Openg Get Cluster Element Names__ogtk.vi
it seems doesn't work if cluster contain map or set
Message 1 of 13
(4,419 Views)
Check if the elements in your cluster constants have non-null labels.
Message 2 of 13
(4,410 Views)
map cann‘t be null???
Message 3 of 13
(4,404 Views)
I don't have the OpenG Toolkit, but when I use the built-in functions, it works for me.
Message 4 of 13
(4,383 Views)
thank you,but i use lots of OPENG VI,This troubles me
Message 5 of 13
(4,373 Views)
Look inside the OpenG code.  See if you can find where things are going wrong.
Message 6 of 13
(4,359 Views)
As far as I know, the OpenG VIs are older than maps and sets and therefore cannot handle maps and sets.
Message 7 of 13
(4,356 Views)
I don't know how to fix
Message 8 of 13
(4,354 Views)
This is true, but on the other hand the Label.Text property is rather basic, implemented in the Control class.
And Maps are undoubtedly controls.
Paolo
Message 9 of 13
(4,326 Views)
This question has been asked and resolved many times already like in this post:
https://forums.ni.com/t5/LabVIEW/Get-the-name-of-each-element-in-my-cluster-in-a-1D-array-of-9/m-p/4...
Simply use the VIs present in the Data Type Parsing palette:
@ pincpanter
Not that simple, if you look at the implementation of "Get Data Name from TD__ogtk.vi", the Pascal string containing the name of the data starts at different offsets in the type descriptor, depending on the data type. The Map/Set case is clearly not implemented (at least in the last OpenG version for LV2021, which I have tested).
Raphaël.
Message 10 of 13
(4,315 Views)
