OpenG on a non-networked computer
Anybody know how to install openg packages (LV 8.6) on a non-networked computer WITHOUT using the PRO version of VIPM?
Message 1 of 9
(3,994 Views)
Message 2 of 9
(3,988 Views)
That method only works for the PRO version of VIPM.  I need a solution with the free version.
Message 3 of 9
(3,981 Views)
I did this once before, if I remember correctly you can move all the packages in the cache directory on a networked computer to a directory on the non-networked computer.  Then go to File->Add packages to package list, then select the location where you put the package files.
~Jonathan
Message Edited by malkier on 10-24-2008 03:34 PM
LV 8.2/8.5/8.6 - WinXP
Message 4 of 9
(3,972 Views)
Ah, sorry. Didn't see that little stipulation.
That's how it is for VIPM. You could try to simply copy the directories over to the other computer, but I pretty much suspect this is not recommended since there are a number of dependencies between packages.
Message 5 of 9
(3,970 Views)
Good point about the dependancies.  I didn't even think about that, but if you download the packages on the networked computer and check for dependancies, then all the packages should be in the cache directory.  I don't remember having a problem with moving them directly, then again I think I downloaded and moved ALL the packages...
Message 6 of 9
(3,967 Views)
That's probably true, but I'll let Jim Kring or someone else from JKI voice their opinion on this since it's their baby.
Message 7 of 9
(3,960 Views)
Getting latest OpenG packages for a non-networked computer -> http://forums.openg.org/index.php?showtopic=307
Message Edited by malkier on 10-24-2008 03:58 PM
Message 8 of 9
(3,956 Views)
That link is for OpenG Commander (which is obsolete) and is not supported/recommended for VI Package Manager.
The supported methods are to add packages to VIPM's package list using the File>>Add Packages menu option or to use a VI Package Configuration file (as described here), which is the easiest method.
If you have more questions about VIPM, we have a support forum, here:  http://forums.jkisoft.com
-Jim
Message Edited by Jim Kring on 10-24-2008 05:25 PM
Message 9 of 9
(3,918 Views)
