OpenG VIPM and Source Safe
Hi all,
I am going to be using Visual Source Safe TFS for my LabVIEW code.  Bascially, I will check in all my code into one folder that is C:\TFS.  I have the following questions.
Where are the tools download from VIPM located at in my harddrive?  How do I keep them in my source safe, since I have to put everything under c:\TFS?
Yik
(3,006 Views)
I would ask the question here http://forums.jkisoft.com/
(3,003 Views)
I believe that  then you have installed "configuration management" sofwtare like VSS or MKS
Now you have installed them you can configure that using LabVIEW itself to perform the operation like Check-in/out , Vew label and all those things.
To configure SCC go to tools->source control->configure source control
Guru
Regards
Guru (CLA)
(2,990 Views)
