OpenG Package Releases
Several packages were revised to fix an issue that was causing the dynamicpallette (OpenG Dynamic Palette View) package to not be installed as a required dependency. The dynamicpalette package is important because it creates the OpenG functions palette category and allows the OpenG libraries to be seen in the functions palette.You can download and install these library packages updates (as well as all the OpenG libraries) using VI Package Manager.
Message 1 of 1
(2,931 Views)
