OpenG Library
Hi all,
Due to some restrictions, I am unable to use VIPM on my PC. Could anyone attach the zipped OpenG Library folder from \Program Files\National Instruments folder?
Thanks in advance! 🙂
-FraggerFox!
Certified LabVIEW Architect, Certified TestStand Developer
"What you think today is what you live tomorrow"
Message 1 of 15
(7,927 Views)
Hi Fragger Fox,
   I have uploaded to the rapidshare folder..Please copy from that as there is some problem with the file size.
   http://rapidshare.com/files/330057488/_OpenG.lib.rar.html
Thanks and reg ards,
srikrishnaNF
Srikrishna
Message 2 of 15
(7,908 Views)
Hi Srikrishna,
Thanks for the reply.
But unfortunately, I can't access rapidshare or other such sites 😞
Could you tell me what is its file size? Is it possible for you to split it and attach?
Thanks!
Message Edited by Fragger Fox on 01-04-2010 12:18 PM
-FraggerFox!
Message 3 of 15
(7,906 Views)
Hi Fragger Fox,
  Actually file size will be 5.79MB.I can t send you this file.Give me your mail-id .I will send it.
Thanks and regards,
srikrishnaNF
Srikrishna
Message 4 of 15
(7,880 Views)
Message 5 of 15
(7,861 Views)
Message 6 of 15
(7,858 Views)
part 3 and joiner vi. keep all these files and joiner vi in single folder and then run the vi. unzip the new file created
Message 7 of 15
(7,853 Views)
hi,
even i am facing the same issue.
i am unable to open the zip files. its says "Cannot open fiels 'XX.zip. It does not appear to be a valid archive'"
Could you please provide them.
-phani
phani srikanth
Message 8 of 15
(6,955 Views)
Do you have access to another PC with the internet (I assume so because you are on NI's forums).  If so then install VIPM and start it.  It will download packages from the repository.  You may need to install them.  Then navigate to C:\ProgramData\JKI\VIPM\cache and you'll find the package files.  Copy them to a USB move them to the other PC.  Install VIPM and then go to File >> Open Package File(s) select your files and install.  If you have the professional version you can make a VI Package Configuration which contains all packages into a single file.
Message 9 of 15
(6,944 Views)
thanks hooovahh,
i dont have admin rights to install any thing in this PC. is there any option to just to dowload the openG drivers and copy to my test pc. it will be very helpfull if you provide the files.
note: i have installed JKI-VIPM in the test pc. only thing i need is openG files.
phani srikanth
Message 10 of 15
(6,928 Views)
