OpenCV "filter2d" is a crosscorrelation, but not like MASM::CrossCorrelation.vi
Question:
What transformations on inputs or settings, assuming equal-sized 2d "src" and "kernel", are required for the MASM::CrossCorrelation.vi to give output consistent with CpenCV::filter2d?
Details:
I have code that is slow that was originally written in Python with OpenCV.
At the heart of this is the OpenCV::filter2d function which, according to OpenCV is really a correlation.
It claims to be a correlation, not a convolution, and in fact gives guidance for how to turn it into a convolution.
How do I go about getting consistent results?  OpenCV has results with signed integer-valued intensities.  LabVIEW has a table with very small coefficients, relatively speaking (1e-7 vs integers [-255,255]).
References:
Update:
  • I'm going to try setting the input to type int8, and see how that impacts this.
(3,433 Views)
What do you think the resolution of the coefficients needs to be to match your previous codes performance?
(3,277 Views)
Do you have some simple input matrices and expected result? What size output do you want? (same?, doublexdouble?)
@EngrStudent wrote:
Update:
I8 seems ill advised, because I guaranteed you'll overflow unless all inputs are <<<11 (a single 11x11 is already close to the max (127) and then you do all the additions on top. Most advanced math functions are only implemented for DBL anyway.
(3,267 Views)
