Open .udl File
I'm trying to open an .udl file to use the third line as the connection string in the LabSQL. Using the notepad I get this information from the file:
[oledb]
; Everything after this line is an OLE DB initstring
Provider=SQLOLEDB.1;Integrated Security=SSPI;Persist Security Info=False;User ID=selco;Initial Catalog=selco;Data Source=STM
But if I use Labview to open the file I get something like this:
[ o l e d b ]
; E v e r y t h i n g  a f t e r  t h i s  l i n e  i s  a n  O L E  D B  i n i t s t r i n g
P r o v i d e r = S Q L O L E D B . 1 ; I n t e g r a t e d   S e c u r i t y = S S P I ; P e r s i s t   S e c u r i t y   I n f o = F a l s e ; U s e r   I D = s e l c o ; I n i t i a l   C a t a l  o g =  s e l  c o ;  D a  ta   S o u r c e = S T M
In the attachment I have included the source code and the .udl. The files missing are just the LabSQL VIs.
Celso Liermann
(3,175 Views)
It's probably a UNICODE file, where each character is represented with 2 bytes. If in LabView you show the string with '\' codes display, you should see the interleaved null bytes.
To get back to ASCII representation, you need to strip out all these extra characters.
Paolo
Paolo
(3,163 Views)
Thank you Paolo for you advice. I fixed my bug using a simple structure.
Celso Liermann
(3,152 Views)
