Open thermocouple detection
How can I enable open thermocouple detection in the Daq config
panel?
I'm using a SCXI-1100 module and a 1303 terminal block.
(2,822 Views)
By default, the SCXI 1303 automatically accounts for an open circuit condition in a thermocouple by applying 5 volts to a pull up resistor in the connector block, thus saturating the instrumentation amplifier for a given channel on the module.
The DAQ cofig setting appears misleading because the window is greyed out and the Open TC Detection setting is not checked.
(2,822 Views)
