Open new VI Window loose control in main Vi
I have a main.vi that have a button that will open a new VI window.
I have no problem opening the new VI window, and passing the data to them.
The only problem is if I have the new VI opened, I cannot change any button state in my main.vi. Is this normal?
Only when I close the new VI window, I have access again to the main.vi.
(2,758 Views)
Can you zip up your VIs and attach here? I can see one place where you disable a control but I'd like to poke around a bit more.
(2,756 Views)
Accepted by topic author PMSilva
Sounds like the vi you are opening is modal. You will need to change that to be able to use buttons in other windows.
Tim
GHSP
(2,751 Views)
Attached is the project.
Thank you
(2,663 Views)
Thank you. That solves my problem.
(2,628 Views)
