Open labview project explorer programatically
How can I open the LV project explorer programatically?
Robert 'Red' hoar
(6,227 Views)
Feed in a project reference:
Message Edited by smercurio_fc on 03-07-2008 10:43 AM
(6,223 Views)
If you want the project to show up also, you can add another invoke afterwards like below:
Message Edited by Van_L on 03-10-2008 11:24 AM
Van L
NI Applications Engineer
(6,193 Views)
I am having some issues opening up a project using relative paths in an executable.  I want to eventually open a VI in another project and put it in a sub panel.  But my first issue is relative paths in executables.
I was putting some code in to check the validity of the relative path.  The VI and project path can be to any project or VI.  To make it all work the VI needs a control labeled "Exit" for shutdown.
I have added the VI that I am using.  It is LabVIEW 2014.
Any thought would be appreciated.
Thanks.
(4,629 Views)
Hi JoeWork,
Given the age of this forum thread you may want to post your question in a new thread for better visibility.
Tyler C.
Technical Support Engineering
(4,619 Views)
