Open handle HTTP
Hello All
Currently i am facing issue onsite that we are not getting response from server (URL). Before that application running smoothly almost 1 and half year without any error. There is not any changes from application side.
So for that i am working on HTTP response logic and found that if i make Verify Server(True) value to Verify Server(False) as seen in attached screenshot, i am getting the response. Earlier by default it is Verify Server(True).
So what is reason that we have to make it false. Please give urgent reply so that i can give proper justification to customer. 
(3,415 Views)
Accepted by topic author parmar483
You are most likely using a https:/: URL and the server certificate is invalid or has expired.
Rolf Kalbermatter  My Blog
(3,357 Views)
Thank you sir
(3,353 Views)
