09-21-2007 12:00 AM
09-21-2007 01:08 AM
If you know the exact complete path, you can very well open the file by using Open/Create/Replace file function from the File I/O pallette.
See to the input "function" it has... You can Open, Open/Create, Create/Replace, Create, Open (read only).
Use the one appropriate to your application.
I suggest you to keep open the online help all the time, to read, understand & code in LabVIEW.
