Open different URLs in same window
I'm developing a program that will be run remotely.
Next to  each control or indicator, I have a little help button that opens up a URL with some information explaining what the control does or indicator means. The problem is that I don't want each help button to open up in a new window. I'd like to have the help info open in a pop-up window. If the user then clicks on a different help icon, then the info in the pop-up window changes (sort of like Labview Context help) as opposed to having a bunch of windows open.
Is there anyway to control which window the URL opens in?
Brian
Message 1 of 9
(5,640 Views)
If there isn't.. why not create a separate VI with embedded webpage (see shipped examples).
When a user presses a help button you main program passes the relevant URL to this separate VI which opens the webpage in the embedded explorer.
Out of interest.. your information about what your buttons is located each at a separate web page?
Cheers,
Battler.
Message 2 of 9
(5,634 Views)
Why not use the conventional help mechanism?
Showing what the control does or indicator means is exactly what it is for.
When you add text to a control's DESCRIPTION field, that text is available when the user has help (control-H) turned on.
It handles the window size for you.
If you must use the web mechanism, try using the TARGET attribute in the link code:
TARGET attribute of ANCHOR tag
If that doesn't get it done for you, post some code.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
Message 3 of 9
(5,610 Views)
How can you include html code when you open a link?  Do you have an example of this?
I've just used the Open URL VI included with LV.  Is there some other way to do it such as you've described?
Cheers.
Message 4 of 9
(5,600 Views)
this may help, you should look it up and see if it can be a solution.
Message Edited by Harold Timmis on 10-11-2009 05:04 AM
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 5 of 9
(5,583 Views)
Cheers
Message 6 of 9
(5,580 Views)
My bad - I was thinking out of the wrong side of my head.
You can't do that with the OPEN URL vi.
Still, what is it about the conventional help mechanism that doesn't work for you?
Steve Bird
Culverson.com
LinkedIn
Message 7 of 9
(5,550 Views)
Can you use context help with remote panels? I'm not sure how to do that, which is why I was going with the browser option.
Message 8 of 9
(5,511 Views)
Have you taken a look at this link? Context help would fall into the localized application feature category and would not show up on the remote computer.
-Zach
Message 9 of 9
(5,489 Views)
