Open .csv file in Excel
If I double click a .csv file in Windows Explorer, then Excel runs and the file is opened.
Is it possible to get LabVIEW to do this?
The problem is, I don't know which version of Excel will be installed, and I also need to accomodate future versions.
Everything I've found with a search seems use to system_exec.vi with a constant pointing to the location (in c:\program files\microsoft office....etc) of a particular version of Excel
So what I want is to have a button which fires an event which takes the specified .csv file and runs whatever version of Excel is installed to open the file.
(3,239 Views)
start file.csv will start whatever application is associated with CSV files.
Br, Miha
(3,233 Views)
Accepted by topic author sebster
Br, Miha
Oh, right. You will most probably need to start cmd.exe to do this: something like
cmd.exe /c "start c:\path\file.csv"
(3,229 Views)
Oooooooh almost.
It's on the right track, but, as is explained here, there needs to be a further pair of quotes in the command line.
So it actually needs something like cmd.exe /c start "" "c:\path\file.csv"
If the extra quotes aren't there then it opens a command prompt window with the path and filename as the window title (WHY???)
But using START is the correct solution, so I'm going to credit you with that.
Thanks.
(3,211 Views)
