Open com port - need to know how to start
I'm trying to collect data so I can use it for analysis, I'm not quite sure where to start. I need to open a virtual com port, and then have the program read the bytes. The packet of data is 1651 bytes long.
Andrea
(4,784 Views)
Open the Example Finder by going to Help >> Find Examples then search for Simple Serial.  The example shows how to send some data, wait, and then read some data back.  There are better designs using synchronous messages but it is a good start.
(4,780 Views)
LabVIEW uses VISA, which stands for Virtual Instrument Software Architecture. Here's an overview of VISA.
The snippet in that article is really all you need to communicate with an instrument. There are other VIs in the palette that help you configure your port and stuff like that. Look through the VISA palette to get familiar.
To start the communication, I would suggest using MAX to make sure you can communicate the way you want. Then take what you do in MAX and implement it in LabVIEW.
Edit: Also, the examples are a great help as Hoovah suggested.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
(4,776 Views)
Accepted by topic author AndreaD
I may echoing the above two comments!
It's very easy to serial communication in labVIEW as we have available pallets.
It works simple as handling a file like (open , read,write and close)
Open and configure with com port,baud rate,parity etc...
Write with specific command before reading specific command.
Read with providing number of bytes of data you expect and close once your communication Is over.
It's always better to create a communication driver with state machine architecture with (open ,write,read,close )options where shift register is used to keep the resources reference
Check with Examples on serial communication to know basics of communication protocol
(4,746 Views)
