annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Open another vi in the main vi
This issue have always be difficult to me undertant, hopely someone can explain this to me.
I have the main Vi which have device controlling, measuring and others tasks. Now i have tryid to open other window (vi) with this (button and event structure http://decibel.ni.com/content/docs/DOC-3413). OK vi opens, but everything stops. The main window stop "runnin" and new window's controls are "not in use". I want to run and control both windows.
Thx again 🙂
-Aa-
0 Compliments
Message 1 sur 4
3 369 Visites
Try making the constant going to Wait until Done false.
Tim Elsey
Certified LabVIEW Architect
0 Compliments
Message 2 sur 4
3 360 Visites
The example is basically how I do it, but I put in a case to skip launching the Vi if it is already running.
=== Engineer Ambiguously ===
Message 3 sur 4
3 343 Visites
You may want to look at this thread for a recient similar solution.  There are two sub vis located in the thread as well and a configuration file.  As previously mentioned- you would want to modify Main.vi by changing the constant wired to Wait for Completion property for your application.
"Should be" isn't "Is" -Jay
0 Compliments
Message 4 sur 4
3 332 Visites
