Open a VI reference from an application
I have a Main module.vi that is calling a Test module.vi by a reference. I use the open VI reference with a strictly typed VI and the Test module.vi is inside a llb.
As VI the Main module is running without any problems. When I build an application of the Main module I get the error 1003 from the open VI reference.
The path to the llb and the Test module.vi is correct.
The idea of this function is that I don't must changing the Main module application in the future when it's running.
The path to the llb is reading out of a config file by the Main module and it is calling the Test module inside the llb.
When I have a new llb, I insert only the new name into the config file. The Main module reading out the new name, I can select it in the program and it will be calling by the Main module.
I hope that anybody can help me with my problem or has an other solution for my idea.
greetings
Sascha
(2,726 Views)
Meanwhile I have found the problem.
The problem was that inside the llb were not all neccessary VIs like VIs from the vi.lib.
Now I build a source distribution with inclusion of all vi.lib, instr.lib and user.lib.
Then I build again the llb and it's running wihtout any problems.
greetings
Sascha
(2,704 Views)
