Open VI Reference error 476
I have been seeing this error but I haven't been able to find any documentation on what it actually means. I only get the error in my application intermittently so I don't have an easy way to troubleshoot to see what may be causing it. If someone could point me to some documentation on this particular error I would appreciate it.
(3,203 Views)
Accepted by topic author scrook
That error code isn't even defined. Are you sure this is coming out of the Open VI Reference function? What are the values of the inputs to that function? Or, is it coming from some other VI that is calling the Open VI Reference function?
(3,193 Views)
It looks like you were right, the error message was actually coming from another VI and I was able to track it back and fix the problem.
(3,175 Views)
